F150 under frame part?
Old Dec 1, 2008 | 09:08 PM
moengle's Avatar
Under my 1997 F150 4x4 frame near spare tire , there is a box like device with wires going to it. Does anyone know what that is ?
Old Dec 2, 2008 | 06:48 AM
kingcrete's Avatar
If it's the Black box directly above the spare, it's the winch system the lowers and raises the spare.
Old Dec 2, 2008 | 07:13 AM
torkum's Avatar
The EVAP canister. Filters the fumes from the gas tank.
Item Part Number Description
1 9F980 Evaporative Emissions Test Port
2 9G271 Evaporative Emission Return Tube
3 9C915 Evaporative Emission Canister Purge Valve
4 9B593 Fuel Vapor Vent Valve
5 9C052 Fuel Tank Pressure Sensor
6 9B593 Fuel Vapor Vent Valve
7 9D665 Evaporative Emission Canister Bracket
8 9D653 Evaporative Emission Canister
9 9F945 Canister Vent Solenoid
10 9002 Fuel Tank
11 9E926 Throttle Body
Old Dec 3, 2008 | 11:12 PM
moengle's Avatar
Yep, probably the fuel evap. Thanks
Old Dec 6, 2008 | 08:11 AM
justusinfla's Avatar
hey torkum
Thank you for the diagram. I was searching threads today because my 1997 just set a P1450 code yesterday.
Do you (or anyone else) have any thoughts as the most likely culprit? The evap system has never been serviced other than a PCV valve or two. The truck has had nothing done to it lately other than turning over 100K miles on Thanksgiving.
Thanks!
Old Dec 6, 2008 | 05:29 PM
update
When I got the code with my Micro Tuner, I cleared it and did the only quick and easy fix I could think of. I removed the gas cap, inspected it, shook it a couple times and put it on and off a couple of times.
Drove it 60 miles today without a code. Fixed for now
