airbag light!!!!!!
Old Oct 10, 2008 | 01:47 PM
nightmare's Avatar
airbag light!!!!!!
i need some help if anyone knows anthing about airbags. my airbag light came on, on my 2003 f150 a couple of days ago and it flashes the code 46, if anyone knows what this means or what i can do to fix it please help me out. thanks
Old Oct 10, 2008 | 02:28 PM
06yz250f's Avatar
my airbag light came on a few months ago. turned out to be a loose connection. there is somewhere to search codes and they tell you what they mean. not sure where tho. sorry.
Old Oct 10, 2008 | 02:35 PM
Found 2 possibilities:
46 LH Crash Sensor - Not Mounted to Vehicle Properly
46 Open Splice Center Air Bag Sensor Ground Monitor
Old Oct 12, 2008 | 12:34 PM
ncranchero's Avatar
From the 2003 Service Manual:
DTC-B1877 LFC-46 LFC Priority24 Driver Pretensioner Circuit Resistance High
NOTE: Most faults are due to connector and/or wiring concerns.
Check the connections of the wiring plugs under the drivers seat.
Old Oct 14, 2008 | 01:53 PM
Oapie07's Avatar
check the passenger air bag light. my connection was loose and it caused the airbag light to flash
Old Oct 16, 2008 | 09:11 PM
projectSHO89's Avatar
He has a fault code 46. The PAD bulb won't cause that, it causes a 27.
Steve
Old Oct 21, 2008 | 01:25 PM
nightmare's Avatar
thanks
thanks to everyone who tried to help me out, turns out it was the connection under my driver seat, thanks carolina five-0.
Old Oct 21, 2008 | 05:01 PM
ncranchero's Avatar
Glad to help out. Wish everything in my life worked that well!
