random beeps
They are not random.
Probably, it's a 5 X 5 signal that your airbag warning light is burned out and that there is also a fault in the airbag system.
Does the airbag light come on during bulb proveout at startup?
Steve
Steve
If there is a fault in the airbag system, you should have a professional look at it. Airbags are not things that someone who is not a trained technician should be messing with. You can replace the bulb if you are capable of dealing with the cluster, but that's about all you should attempt to do yourself.
