F150 hard to start
Old Sep 24, 2008 | 09:55 PM
A. It should work fine.
B. No, replace that hose.
c. You are welcome!
Old Sep 24, 2008 | 10:58 PM
HappeetxnR.N.'s Avatar
Cleaned the throttle body and intake (gunk and build up)
Replaced the hose that was flattened
cleaned and inspected everything
Now it fires right up and idles a lot smoother.
Craig
Old Sep 24, 2008 | 11:00 PM
noonespecial's Avatar
1. Fuel Filter
2. If not IAC, check for vacuum at IAC, listen for vacuum leak ANYWHERE
3.Fuel Pressure,HOPE IT AINT THIS, changin fuel pump is a BBEEEEAAAATCHH!!
4.Check how strong spark is at coil/coils, when they go bad they work good until they warm up, then they work but not so good.
Dont be fooled at the mileage, your good for another 100k.
