Lost keys and remote entry
Old Sep 5, 2008 | 03:00 PM
HappeetxnR.N.'s Avatar
Dealership say I have to have the truck towed in because they have to have the truck to program a new key.
My question is.........Any way around this?
Craig
Old Sep 5, 2008 | 03:33 PM
JD790's Avatar
Nope. Truck has to be present so they can hook up a scan tool and program a new set of keys. Also, be prepared to buy a minimum of 2 keys, because that is the minimum amount that the PATS system requires when starting over from scratch.
Old Sep 5, 2008 | 03:39 PM
rednoved's Avatar
do those keys have chips in them? what year did they start that?
if they didnt have the chip, you used to be able to order new keys by the VIN number.
Old Sep 5, 2008 | 03:57 PM
Dealership says my 99 has the chip in it.
Craig
Old Sep 5, 2008 | 03:59 PM
exitwound's Avatar
Take one of the new PATS keys they give you and tape it to the PATS module then you can get a key cut without the chip if you need to and not have to go to the hassle of having the dealership charge you for this reprogramming.
Of course do this and the chances of someone getting into your car and actually starting it go up.
Old Sep 5, 2008 | 08:02 PM
minimonster17's Avatar
uhh... if even if you cut the key perfect, the truck will not start w/o the transponder being programmed, hence the necessity of the dealer's services. there's no way around this. you can't just tape a non-programmed transponder key to the PATS, and cut a non-transponder key to use to start the ignition. the best you could do is tow the truck to the dealer's w/ a buddy's truck/trailer, and save on the tow bill.
Old Sep 5, 2008 | 08:46 PM
hburns61's Avatar
The remote entry fobs are available on ebay cheaply, about $15 each. And you can program it yourself (after you have a new key). It'll come with directions.
Old Sep 6, 2008 | 05:15 PM
Bear with me on my lack of knowledge....is FOBS the same as PATS? And on Ebay do I just put in FOBS?
Thanks for all of the replies and suggestions.
Craig
Old Sep 6, 2008 | 05:53 PM
exitwound's Avatar
I meant it was an option after he took the truck to a dealer and got it reprogrammed with new keys.
Old Sep 6, 2008 | 05:55 PM
exitwound's Avatar
Craig
PATS is Passive Anti-Theft System
Go to eBay and type in F-150 Keyless Remote and you will get a couple hundred options.
Either way you go you will still need to go to the dealer and get the truck reprogrammed though.
Old Sep 6, 2008 | 06:32 PM
Cool. Thanks for the info.
Craig
Old Sep 7, 2008 | 11:58 AM
A fob is the remote clicker that goes on your keychain.
Old Sep 7, 2008 | 01:58 PM
I will look into all of the info posted above.
Big TEXAS thanks for all of the help
Craig
Old Sep 7, 2008 | 02:02 PM
exitwound's Avatar
Big Texas your welcome!
