3" body lift installed...
my 97 f150 4x4 has a 3 inch body lift with custom fit panels on the rear to cover the new body-frame gap that was created with the lift.
I need to know where to order (or what type of material to use) the inside fender material (soft foam/rubber?).
the exaust manifold is exposed and would like to cover a little bettter....
thanks in advance for yall's help
I bought the 3" body lift and a set of "lift lips" to cover the gaps. I bought both from 4wheelparts.....lips are about $60, I think, but it is a full set for all 4 wheel wells....
How was the install??? How long did it take??? Did you have any help???
Did you lift the body and bed together or seperately as stated in the directions.....
Most importantly, would you do it again????
