Currie Brakes?
Old 02-02-2007, 10:09 AM
Ruune's Avatar
Currie Brakes?
Anyone heard of these? 4 wheel parts has 11" rotors, pads, calipers, and related hardware for $484.85:
http://www.4wheelparts.com/PDT73469.aspx
Old 02-02-2007, 02:05 PM
Robert Currie's Avatar
Hey bro what questions do you have about our brakes...?
Description: Our most economical disc brake features 11" solid rotors, single piston calipers with pads, backing plate/caliper mounting bracket plates with the drum style parking brake assembly installed. Specify wheel bolt pattern (up to 6 x 5 1/2") and stud hole size that you would like drilled in the rotors. PLEASE NOTE: This kit will only fit on rearends with that are equipped with Torino style late model large bearing housing ends and aftermarket axles with a 2.500" brakespace offset.
Old 02-02-2007, 02:10 PM
Ruune's Avatar
how do they compare with the factory setup- i.e. stopping power, fade, noise, dust, etc. I pull a 6000-lb wakeboard boat with my F150, and its got 50k miles on it now. my factory discs are starting to pulse, and instead of getting the factory ones turned and new pads put on, I figured that I'd just upgrade. Also, does the package I linked to include all four or just the front (or back)?
Old 02-02-2007, 02:20 PM
These wont work on your F150 , the will work only with the Ford 9 inch housing end (late style torino) and REAR ONLY... You either have an 8.8 rear or a 9 3/4 like mine... Might try upgrading to a different caliper... Call Baer Brakes or Wilwood and see if they offer and upgrade caliper.. Hope this helps... I'm having Speedo Issues right now driving me crazy..
Old 02-02-2007, 02:35 PM
Ruune's Avatar
doh! thanks for the info anyways!
Quick Reply: Currie Brakes?
