Question for Kingfish...
I just got Toyo Open Country AT's, 285/75/17's... I'm not sure on the load range, but I'd guess probably 'E'. Max pressure on the sidewall is 65psi. The shop put 38 in them and said thats all I need unless I put a large load in the bed... Doesn't sound right to me... What's your recomendation?
Took a look at the Toyo site. Only see 285/70R17 listed in 17" rims. Those show a LR that would make it around a LR E, 3105lbs, they didn't list it specifically. I would run those no lower than about 44. As the max is 65, 50 might be a little high, but not by much if any. That is what I would use if it was a LR E with 80psi max. As for 38n would be okay without a load, maybe, although I still think it is low for a LR E. As far as running it lower, I certainly am not going to remember or want to put air in every time I carry something. Try the 50 and see how it wears and rides. I doubt with that you will have to ever add when carrying or towing anything, and it should ride just fine unloaded.
Edit - Let us know how it does and what pressure you decide to go with. All the experience I have with LR E tires is with those that max at 80. Those work well at 50 on an F150.
