Lift/tires help!!!
Lift/tires help!!!
i have a 1986 ford f1504x4.. i300. I was wondering what would be the biggest tire i can run stock??? or should i go ahead and buy a 4 or 6 inch lift?? i just thought id try to stay at stock or 4' becuase if i went with 6' lift and just saying if i baught 33X11.5X15's they would look tiny and wouldnt want to go much bigger than those with a whole stock front and rear end?? help pleease!
How wide is the rim? If its' around 7" wide, then 11.5 would be the max.
If I was you, I'd just look at getting new rims anyways, something like a 15x8 or 15x10.
Plenty of good used ones on Ebay, plus the lift kits are cheap to buy on there as well.
You Manitoba farmers should be able to install it yourselves too...LOL
