Help with new wheels
Hello, im new to these forums. Im looking to get some new wheels and tires. Im looking into the Pro Comp Extreme 7089 wrapped in BF Goodrich All-Terrarin T/A KO tires to go on my 2002 F150 Supercrew XLT 4x4 but im not sure if they will work. Does anyone know the offset of the stock rims? or do you know if these will fit fine? Just wanna make sure there will be no problems if i get them. Or if you have any other suggestions on what to get that would be nice. My truck is stock, and the type of driving I do is basically normal but I want some nice big tires and some nice rims. Any help will be greatly appreciated
THe OEM 16 inch wheels for your truck are 7 inches wide with 4.5 inches of backspacing. The OEM 17 inch wheels are 7.5 inches wide with 4.5 inches of backspacing. Our trucks have a 5x135mm bolt pattern. I'd suggest going with a 16x10 inch wheel with 4.5 inches of backspacing and 305/70-16 (33x12.50) tires. You will have to trim a little plastic off your front bumper's lower valance to fit this combo.
Thanks alot, so will any of these work? http://www.procomptires.com/series7089.htm Will it work with the -25 offset?
