need some help on rim size
Hey guys i was wondering if this would work I have a 2006 F150 XLT 4x4 with a 2" leveling kit and i was looking at this combo
Tires:BFG AT 285/70-17
Rims:Pro comp 7089 series 17x8
bolt pattern: 6-135
back spacing: 4.5
offset: 0
any help would be great
Thanks John
bolt pattern: 6-135
back spacing: 4.5
offset: 0
Thanks John
Yes, that combo will work, if they will fit over your brakes. You see, Ford changed brake calipers sometime during the 2005 model year. THis is causing problems with some (not all) aftermarket 17 inch wheels. Just be sure to test fit a wheel first. Those wheels will stick out about 1.5 inches farther than your OEM wheels.
any word if they fit? i am going to be running the same set up just different sizes......im thinking......
pro comp series 7089
17x9 rims (backspacing 4.75)
33x12.50x17
i hope the wheels fit....kind of worried...Wandell how can i tell if they fit without actually trying to put them on (ordering online)
33x12.50x17
