Truck pulling hard to the right
Old 01-11-2006, 07:41 PM
dye7barrel's Avatar
I did the brakes on the truck ('99 F-150 117k miles) a few thousand miles ago and now under hard braking, the truck pulls hard to the right. If I'm going 50 or so and hit the brakes, the pull is hard enough to take me into the ditch. However, if I lightly apply the brakes then hit them hard, the truck doesn't pull nearly as much. I pulled the calipers off and regreased the slides and the problem is still there.
Old 01-11-2006, 09:29 PM
zapster's Avatar
the caliper piston is worn to the original pads..
sorta crooked in the bore
when you installed the new pads they tried to "straighten out" the piston..
they dont like that
thus the hanging up and pulling to one side
all the grease in the world will do no good
change out the calipers... you'll see
...zap!
Old 01-11-2006, 10:36 PM
dye7barrel's Avatar
Ummm......so far I've deciphered new calipers......
Old 01-14-2006, 12:31 AM
LilBlackCoupe's Avatar
Sounds like you have a caliper sticking or brake hose expanding.
When you did your brake job... did you replace pads and rotors??
Old 01-16-2006, 11:07 PM
dye7barrel's Avatar
Yep, replaced the rotors and pads along with new fluid.
Old 01-18-2006, 11:14 AM
jkingman's Avatar
I had a similar issue a while back, it was actually overheating and warping my rotor to a certain extent (driver side) - upgraded the calipers to a three-piston configuration (I'll look for the receipt to tell you where I got them if you're interested) and changed out the rotors to a set of drilled ones... problem solved.
...not that you would need to go to that extreme, but I really noticed the difference when I was braking during towing or had to come to a quick stop from high speeds...
...lol, not that there is a such thing as stopping quickly at high speeds with that truck, but it certainly felt a lot more confident under heavy braking.
Old 01-18-2006, 06:57 PM
dye7barrel's Avatar
jkingman-If you have the receipt handy that would be great. I'll be replacing the calipers later this week or during the weekend and I'll report back if anything changes.
Quick Reply: Truck pulling hard to the right
