Best Look with 3 inch body lift
I have a 2003 F150 Regular Cab Short Bed with a Performance Accessory Body Lift. I also had additional panels installed in the wheel wells for a better look.
I am considering a suspension lift as well (already posted questions in the area), but if I decide not to get a suspension lift,,,,what size wheels would look best ( and will fit) for the 3 inch body lifted truck?
Once I understand the wheel options, I will look for tires - Probably Bridgestone Duelers Revo (based on what I have read so far).
Appreciate your time and advice.....
It is a 4x2....the tires you suggested,,,,what wheels would be needed? do I use the existing stock wheels,,,or upgrade to larger wheels and larger tires.
Guess my badly worded question is: What is the largest size wheels and tires could I get away with if I have only had a 3 inch body lift?
