Need help from the pros
Old 05-22-2005, 07:49 AM
RhinoF150's Avatar
I have an '04 FX4 Screw with leveling kit and am dropping down to a 17" wheel. I am looking at the Pro Comp Extreme 1079 (no bling) 17x9 with +2mm offset and 5 inch backspacing wrapped with Nitto Terra Grappler 295/70 17 (33.19x12.13 according to Nitto). Can you see any problems with this setup as far as clearance or rubbing? Thanks for the help.
Old 05-22-2005, 09:36 AM
wandell's Avatar
Sounds like a good combo to me.
Old 05-22-2005, 11:09 AM
RhinoF150's Avatar
Thanks Wandell, knew I could count on your reply
Old 05-22-2005, 11:54 PM
STXFX4's Avatar
I have the same wheel in 18 wrapped with 325/65/18 NItto Terra Grappler AT, and it works great. I think you will be very satisfied with the set up. Very little weight was needed to balance the tire and wheel
Quick Reply: Need help from the pros
