Rabs
Rabs
I replaced the rear sensor on the rearend and the light remains lit. What else can i check whats left to check its only rear abs. Is there any sensors on the brakes themselves??. The rear brakes are OEM with 136,000 on them but they look good. Fluid level is good contacts are good going into the abs unit under the master cylinder. I am now baffled any help would be a plus here.
