Searched for someone to answer, but have had NO success. Someone please help me!!
I've searched for someone with this same scenerio, but to no luck.
I have a 2003 F150 reg cab step side. Now it's the 4.6L and i have the FX4 package with the 17 inch wheels.
Now i work here at the BFG tire plant here in Tuscaloosa, AL, and have asked around everyone that works here but gotten MANY DIFFERENT responses.
I recently ditched the 265 goodyears that were stock and put on a set of 285/70R/17's Mud Terrain's on. Now they fit just fine here at stock height and don't rub even in a bind. My question is can i fit a set of 315/70R/17 Mud Terrains under there with ONLY a leveling kit? I ONLY wanna havta use a leveling kit for $160 versus a $1000 lift kit. And maybe just a homemade block for the back. I don't wanna spend some $1000 on a 2" lift kit.
ANYONE please help. All help GREATLY appreciated :-)
on
Originally posted by APT
...Expect odd behavior from the transmission and a total loss of power unless you change your rear differential gears.
Originally posted by Raoul
He'll just have to get used to getting the bird flipped by the faster traffic stuck behind him, such as a nun on a bicycle.
What gear ratio do you have? I had 315s with the stock 3.55 gears for awhile. Under light to moderate throttle, it would be OK, although the torque converter would stay unlocked for alot longer = bad for your tranny. Plus cruising on the highway was more difficult because it didn't have any getup. If you have a manual, say goodbye to 5th gear.
If you have anything less than 3.73s, you'll be lugging the hell out of your truck. I would personally stick with the 285s. Not to mention that a 7.5" wheel is too narrow for a 12.50 tire.
Mike
