Best Tires out there for good price?
You have either 16x7's or 17x7.5 inch wheels. You can easily fit 33's whether you go with 285/75-16's, 285/70-17's (33x11.50), 305/70-16 (33x12.50) or 33x12.50-17's. Also, for the money, the Nitto Terra Grapplers are probably the best value. They are just as good as BFG AT KO's, but less expensive.
i just put on 315/75/12.5 on a 16x10 wheel. they look sharp!!! im a 2x4 with 7.5'' lift, and i had to hammer at my fenders so i wouldnt get rub when i turned. ive got the 4.6 v8 and have not noticed a difference in power and tork. but i will have to regear asap... my gas milage is at 9.5 mpg instead if 16. im also about an inch higher than you. go with the 305s. check out the nitto terra grplers and mud terrain. keep in mind there website does them no justice!!!
