wheels and tires for 03 f150 flareside
Mine are 285/50 HR20. They are a little taller than stock and my speedo is off by about 4%. But I wanted a little taller tire to fill up the wheelwell. A 295/40 20 will fit and the circumference is the same as what you have now so your speedo will be ok. It depends on what you want. A 275/45 20 is also the same circumference as stock also, but is too narrow for my taste. It's the same size that the 01-03 Harley F-150s use.
As for posting a pic....when you are posting you click on the "IMG" button and put in the address of where the pic is.
