Adjusting Rear Drums
Another common problem for Ford rear brakes is for the brake adjuster cables to stretch and not 'catching' the adjuster. If you can rotate the adjuster in both directions, you probably have a stretched cable. Need to pull the drums and replace the cable. It doesn't take too long to do. Would also be a good time to lube the adjuster.
