Tires Rubbing
Tires Rubbing
I have a 2000 F150 XLT 4x2 that has a 3 inch Fabtech lift and a 3 inch body lift with 35" BFGs. I just starting to rub the inner wheel well on hard turns. The install place wants to cut the plastic liner back pretty far. I know this is a fairly common lift (at least in southern CA), is this common? Or will trimming the liner back cause problems down the road? Thanks for any help or recommendations.
Jeffc, I have the 3" Spindle lift and a 3" body lift + a 1" coil spacer. Mine rub the black plastic behind the front tire too. What we were conserned about was behind that plastic is a piece of metal thats thin and coul possibly rip open the tire. So we took the plastic out and cut a slit in the metal and bend it back. We also cut out a different piece of metal at the bottom. (None of this is visible unless you take tha plastic out.) Then we put the plastic back in and I don't have to worry about tearing up my tires. If yours is only rubbing the plastic then I would be too conserned about it until it rubs through the plastic and starts rubbing the metal.
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, 5 Speed, Superchip, 2 Superchip Decals (I Think They Add 5 HP Each), 3 Inch Bullseye Lift Spindles, 3" Body Lift, 1" Coil Spacers, 3" Blocks In Rear,Manik Grill Guard,Nerf Bars, Vent Visors,Air Box Mod, Fog Lights Mounted In Front Air Dam ,4 Kc DayLighters, Back Up Lights, Alpine CD Player, 2 Kenwood Amps,Polk Audio DX7 5X7's In The Front Doors, 10 Inch MTX Blue Thunder SubWoofer, Tinted Windows. 35" BFGOODRICH ALL TERRAIN KO'S Mounted on 16.5x9.75 American Racing Baja Rims
<A HREF="http://www.zing.com/picture/pf95408d4c385a927598e7884a5151a2a/ffd9add3.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p7e554b755e2bb9aa66f774b76d669a34/ffd9add2.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/pe0557f5ae565a8da25e9ce11b08009df/ffd9add1.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p810cf5ac82eb57b84a62f699fb0f38e7/ffd9ad72.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p3d23039451896f609154656f22698b8f/ffd991ca.jpg" TARGET=_blank> </A>
CLICK THE PIC FOR A BIGGER ONE
..........."IF YOU CAN'T STOP, SMILE AS YOU GO UNDER"...........
'00 Toyota Celica GT( Wife's Car )<A HREF="http://www.zing.com/picture/p5ef23f8639c03b4f05f21e4f35c15cfb/ffd9ad71.jpg" TARGET=_blank> </A>
Pics @ http://www.angelfire.com/la2/ccla/
[This message has been edited by ccla (edited 06-08-2000).]
