99 F150 5.4 stumbles while heating up
My truck began 'stumbling' when the engine is not quite to operating temperature. I call it 'stumbling' since it feels more like running an engine with incorrect A/F ratio rather than a misfire. But when heated up it's much better but still has an occasional problem that now feels like a misfire! It actually does better with the A/C on.
No codes or check engine light.
I only have about 128K miles on the truck and the plugs were replace at about 85K when a plug coil went bad.
Before I spend a bunch of money letting Ford randomly replace stuff... does anyone have an idea what the real problem might be?
Thanks for your words of wisdom.
Ford scores $$ but now it runs like new
Not aware of a convenient and knowledgeable Ford mechanic in the Duluth, GA area other than the dealership. So here I go for the high dollar fix. They found 2 COP's that were 'weak', No. 3 and No. 5 cylinders. After replacing the COP's, two plugs, decarbonizing and $623 she runs like new again!
Not bad when I think about it.... a 15 yr old truck I've only spent about $1200 dollars on in what I consider abnormal repairs. 3 COP's, a fuel pump, and a passenger side door lock.
