does this scan give a clue
opps, addl data
Sorry guys, thought I typed it in, got distracted. Cold start gives 15 to 20 seconds of normal then a hard loping idle that sometimes dies. Only does so when outside temp below 45. The above stats are all my scanner reads and the mid point of data is right where lope hit full on. Drives fine (far as I can tell) soon as you come off idle. Usual suspects (IAC, IAT, MAF, DPFE and hoses) all replaced already.
While I understand a cylinder head temp sensor could mess with the computer's calculations, how could the cold weather affect the CHT sensor? I mean right on the engine it should heat up regardless of the outside air temp.
