MERGED: DTC List
Old 12-06-2007, 08:01 PM
i.ride.suzuki's Avatar
DTC List
DTC Index
PCM - Powertrain Control Module
P0010 Intake Camshaft Position Actuator Circuit/Open (Bank 1)
P0011 Intake Camshaft Position Timing - Over-Advanced (Bank 1)
P0012 Intake Camshaft Position Timing - Over-Retarded (Bank 1)
P0016 Crankshaft Position - Camshaft Position Correlation - Bank 1 Sensor A
P0018 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor A
P0020 Intake Camshaft Position Actuator Circuit/Open (Bank 2)
P0021 Intake Camshaft Position Timing - Over-Advanced (Bank 2)
P0022 Intake Camshaft Position Timing - Over-Retarded (Bank 2)
P0040 Oxygen Sensor Signals Swapped Bank 1 Sensor 1/Bank 2 Sensor 1
P0041 Oxygen Sensor Signals Swapped Bank 1 Sensor 2/Bank 2 Sensor 2
P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
P0068 Manifold Absolute Pressure (MAP)/Mass Air Flow (MAF) - Throttle Position Correlation
P0102 Mass or Volume Air Flow A Circuit Low
P0103 Mass or Volume Air Flow A Circuit High
P0104 Mass or Volume Air Flow A Circuit Intermittent/Erratic
P0106 Manifold Absolute Pressure (MAP/BARO) Sensor Range/Performance
P0107 Manifold Absolute Pressure (MAP)/Barometric Pressure (BARO) Sensor Low
P0108 Manifold Absolute Pressure (MAP)/Barometric Pressure (BARO) Sensor High
P0109 Manifold Absolute Pressure (MAP)/Barometric Pressure (BARO) Sensor Intermittent
P0112 Intake Air Temperature (IAT) Sensor 1 Circuit Low
P0113 Intake Air Temperature (IAT) Sensor 1 Circuit High
P0114 Intake Air Temperature (IAT) Sensor 1 Intermittent/Erratic
P0116 Engine Coolant Temperature (ECT) Sensor 1 Circuit Range/Performance
P0117 Engine Coolant Temperature (ECT) Sensor 1 Circuit Low
P0118 Engine Coolant Temperature (ECT) Sensor 1 Circuit High
P0119 Engine Coolant Temperature (ECT) Sensor 1 Circuit Intermittent/Erratic
P0121 Throttle/Pedal Position Sensor A Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor A Circuit Low
P0123 Throttle/Pedal Position Sensor A Circuit High
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0127 Intake Air Temperature (IAT) Too High
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0132 O2 Circuit High Voltage (Bank 1, Sensor 1)
P0133 O2 Circuit Slow Response (Bank 1, Sensor 1)
P0135 O2 Heater Circuit (Bank 1, Sensor 1)
P0138 O2 Circuit High Voltage (Bank 1, Sensor 2)
P0141 O2 Heater Circuit (Bank 1, Sensor 2)
P0144 O2 Circuit High Voltage (Bank 1, Sensor 3)
P0147 O2 Heater Circuit (Bank 1, Sensor 3)
P0148 Fuel Delivery Error
P0152 O2 Circuit High Voltage (Bank 2, Sensor 1)
P0153 O2 Circuit Slow Response (Bank 2, Sensor 1)
P0155 O2 Heater Circuit (Bank 2, Sensor 1)
P0158 O2 Circuit High Voltage (Bank 2, Sensor 2)
P0161 O2 Heater Circuit (Bank 2, Sensor 2)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0180 Fuel Temperature Sensor A Circuit
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low
P0183 Fuel Temperature Sensor A Circuit High
P0190 Fuel Rail Pressure Sensor A Circuit
P0191 Fuel Rail Pressure Sensor A Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor A Circuit Low
P0193 Fuel Rail Pressure Sensor A Circuit High
P0196 Engine Oil Temperature (EOT) Sensor Circuit Range/Performance
P0197 Engine Oil Temperature (EOT) Sensor Circuit Low
P0198 Engine Oil Temperature (EOT) Sensor Circuit High
P020x Injector Circuit/Open - Cylinder X
P0210 Injector Circuit/Open - Cylinder 10
P0217 Engine Coolant Over-Temperature Condition
P0218 Transmission Fluid Temperature Over-Temperature Condition
P0219 Engine Over Speed Condition
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High
P0230 Fuel Pump Primary Circuit
Old 12-06-2007, 08:03 PM
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0234 Turbocharger/Supercharger A Overboost Condition
P0243 Turbocharger/Supercharger Wastegate Solenoid A
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0297 Vehicle Over Speed Condition
P0298 Engine Oil Over Temperature Condition
P0300 Random Misfire Detected
P030x Cylinder x Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0315 Crankshaft Position System Variation Not Learned.
P0316 Misfire Detected On Startup (First 1000 Revolutions)
P0320 Ignition/Distributor Engine Speed Input Circuit
P0325 Knock Sensor 1 Circuit (Bank 1).
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1)
P0330 Knock Sensor 2 Circuit (Bank 2).
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0340 Camshaft Position Sensor A Circuit (Bank 1 or single sensor)
P0344 Camshaft Position Sensor A Circuit Intermittent (Bank 1 or single sensor)
P0345 Camshaft Position Sensor A Circuit (Bank 2)
P0349 Camshaft Position Sensor A Circuit Intermittent (Bank 2)
P0350 Ignition Coil Primary/Secondary Circuit
P0351 Ignition Coil A Primary/Secondary Circuit
P0352 Ignition Coil B Primary/Secondary Circuit
P0353 Ignition Coil C Primary/Secondary Circuit
P0354 Ignition Coil D Primary/Secondary Circuit
P0355 Ignition Coil E Primary/Secondary Circuit
P0356 Ignition Coil F Primary/Secondary Circuit
P0357 Ignition Coil G Primary/Secondary Circuit
P0358 Ignition Coil H Primary/Secondary Circuit
P0359 Ignition Coil I Primary/Secondary Circuit
P0360 Ignition Coil J Primary/Secondary Circuit
P0400 Exhaust Gas Recirculation (EGR) Flow
P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient Detected
P0402 Exhaust Gas Recirculation (EGR) Flow Excessive Detected
P0403 Exhaust Gas Recirculation (EGR) Control Circuit
P0405 Exhaust Gas Recirculation (EGR) Sensor A Circuit Low
P0406 Exhaust Gas Recirculation (EGR) Sensor A Circuit High
P0410 Secondary Air Injection (AIR) System
P0412 Secondary Air Injection (AIR) System - Switching Valve A Circuit
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0442 Evaporative Emission System Leak Detected (Small Leak)
P0443 Evaporative Emission System Purge Control Valve Circuit
P0446 Evaporative Emission System Vent Control Circuit
P0451 Evaporative Emission System Pressure Sensor/Switch Range/Performance
P0452 Evaporative Emission System Pressure Sensor/Switch Low
P0453 Evaporative Emission System Pressure Sensor/Switch High
P0454 Evaporative Emission System Pressure Sensor/Switch Intermittent
P0455 Evaporative Emission System Leak Detected (Gross Leak/No Flow)
P0456 Evaporative Emission System Leak Detected (Very Small Leak)
P0457 Evaporative Emission System Leak Detected (Fuel Cap Loose/Off)
P0460 Fuel Level Sensor A Circuit
P0461 Fuel Level Sensor A Circuit Range/Performance
P0462 Fuel Level Sensor A Circuit Low
P0463 Fuel Level Sensor A Circuit High
P0480 Fan 1 Control Circuit
P0481 High Fan Control (HFC)/Fan Control 3 (FC3) Primary Circuit Malfunction
P0482 Medium Fan Control (MFC)/ Fan Control 2 (FC2) Primary Circuit Failure
P0483 Variable Fan Control (FC V) Fan Performance
Old 12-06-2007, 08:04 PM
P0491 Secondary Air Injection (AIR) System Insufficient Flow (Bank 1)
P0500 Vehicle Speed Sensor (VSS) A
P0503 Vehicle Speed Sensor (VSS) A Intermittent/Erratic/High
P0505 Idle Air Control (IAC) System
P0506 Idle Air Control (IAC) System RPM Lower Than Expected
P0507 Idle Air Control (IAC) System RPM Higher Than Expected
P050A Cold Start Idle Air Control Performance
P050B Cold Start Ignition Timing Performance
P0511 Idle Air Control (IAC) Circuit
P0528 Fan Speed Sensor Circuit No Signal
P0532 Air Conditioning Pressure (ACP) Sensor Low Voltage Detected
P0533 Air Conditioning Pressure (ACP) Sensor High Voltage Detected
P0534 Low A/C Cycling Period
P0537 A/C Evaporator Temperature (ACET) Circuit Low Input
P0538 A/C Evaporator Temperature (ACET) Circuit High Input
P0552 Power Steering Pressure (PSP) Sensor/Switch Circuit Low
P0553 Power Steering Pressure (PSP) Sensor Circuit High Input
P0579 Cruise Control Multifunction Input A Circuit Range / Performance
P0581 Cruise Control Multifunction Input A Circuit High
P0600 Serial Communication Link
P0602 Powertrain Control Module (PCM) Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 Powertrain Control Module (PCM) Processor
P0607 Control Module Performance
P060A Internal Control Module Monitoring Processor Performance
P060B Internal Control Module A/D Processing Performance
P060C Internal Control Module Main Processor Performance
P0611 Fuel Injector Control Module Performance
P061B Internal Control Module Torque Calculation Performance
P061C Internal Control Module Engine RPM Performance
P061D Internal Control Module Engine Air Mass Performance
P061F Internal Control Module Throttle Actuator Controller Performance
P0620 Generator Control Circuit
P0622 Generator Field Terminal Circuit
P0625 Generator Field Terminal Circuit Low
P0626 Generator Field Terminal Circuit High
P062C Internal Control Module Vehicle Speed Performance
P0645 Air Conditioning Clutch Relay (A/CCR) Primary Circuit Malfunction (Also Referred to as WAC Circuit)
P0657 Actuator Supply Voltage A Circuit/Open
P0660 Intake Manifold Tuning Valve (IMTV) Control Circuit Open - Bank 1
P0685 Electronic Control Module (ECM)/Powertrain Control Module (PCM) Power Relay Control Circuit/Open
P0689 Electronic Control Module (ECM)/Powertrain Control Module (PCM) Power Relay Sense Circuit Low
P0690 Electronic Control Module (ECM)/Powertrain Control Module (PCM) Power Relay Sense Circuit High
P0703 Brake Switch B Input Circuit
P0704 Clutch pedal position CPP switch malfunction.
P0705 Transmission Range Sensor A Circuit (PRNDL) Input
P0707 Transmission Range Sensor A Circuit Low
P0708 Transmission Range Sensor A Circuit High
P071x Transmission code
P0720 Output Shaft Speed (OSS) Sensor Circuit
P0721 Output Shaft Speed (OSS) Sensor Circuit Range/Performance
P0722 Output Shaft Speed (OSS) Sensor Circuit No Signal
P0723 Output Shaft Speed (OSS) Sensor Circuit Intermittent
P073x Transmission code
P074x Transmission code
P075x Transmission code
P076x Transmission code
P077x Transmission code
P078x Transmission code
P079x Transmission code
P0815 Upshift Switch Circuit
P0830 Clutch Pedal Switch A Circuit
P0833 Clutch Pedal Switch B Circuit
P0840 Transmission Fluid Pressure Sensor/Switch A Circuit
P09xx Transmission code
P1000 On-Board Diagnostic (OBD) Systems Readiness Test Not Complete
P1001 Key On Engine Running (KOER) Not Able To Complete, KOER Aborted
P1100 Mass Air Flow (MAF) Sensor Circuit Intermittent
P1101 Mass Air Flow (MAF) Sensor Out of Self-Test Range
P1112 Intake Air Temperature (IAT) Circuit Intermittent
P1114 Intake Air Temperature 2 (IAT2) Circuit Low (Supercharged/Turbocharged engines)
Old 12-17-2007, 11:56 PM
MERGED: DTC List
Here is a complete DTC List thanks to jbrew and ManualF150.
jbrew's List
jbrew's OBDII code list has both powertrain "P" codes and body/electrical "B" codes.
ManualF150's List
ManualF150's list is a generic list, useful for not only Fords but many other makes. It does however distinguish which special code is for which makes, which makes it easier. This list does NOT contain "B" codes.
Enjoy.
Old 11-17-2008, 11:19 AM
Rockpick's Avatar
Moderator &
If you have an additon or suggestion to go with this list, please PM or EMAIL it to me... Going to keep this thread locked so that we can keep discussion about the codes within other threads.
Quick Reply: MERGED: DTC List
