code p0174
Old 03-15-2007, 07:30 PM
nitro22's Avatar
Exclamation code p0174
okay i scan my 01 f150 v6 4.2 i got three codes one was an 02 sensor (p0153 bank 2 sensor 1) the other codes were p0171 System too lean bank 1.! and the other code was p0174 system too lean bank2! k i replaced the 02 sensor and it clear the 2 codes the (p0153) and (p0171) but the p0174 keeps on comin up i wanna replace the other 02 sensor on bank 1 you guys think that would help since it cleared when i replace the 02 sensor on bank2??? any suggestions im takin my emissions test next month i got to clear the code..... !!!!!!!!!!
Old 03-15-2007, 07:34 PM
torkum's Avatar
Do a search in the V6 section for intake gaskets leaking.
Old 03-15-2007, 07:41 PM
jbrew's Avatar
Those codes tell you your O2's are working as they should- perfectly...
You have a vac leak and/or a dirty MAF sensor..
Old 03-15-2007, 07:54 PM
nitro22's Avatar
okay thanks!!! but im kind of new to these stuff how do i look for a vac leak and where is the maf sensor is there a way i can clean it or do i have to replace it..??
Old 03-15-2007, 08:14 PM
jbrew's Avatar
idunno , try the V6 section or maybe someone else will chime in that know's..
Quick Reply: code p0174
