Rear Pinion Seal
When you removed the pinion nut and seal you changed the pinion bearings preload. That changed the pitch of the whine.
I had a loose pinion nut and retightned. I was warned I may have problems later, but my loud whine went away. I picked up another 8.8 axle just in case. This was for '89, my 99' has the 10.25.
Ditto... the whine was being caused by the pinion bearings. Re-torquing the pinion flange nut may have changed the sound, but it's likely that the pinion bearings are already shot. You're going to want to have those replaced along with the crush washer sometime soon before the bearings grenade themselves. It's only a matter of time right now...
-Joe
-Joe
To echo the statements from above, it is the pinion bearings that are making the whine more than likely. Mine usually started the whine when I would get up around 50-60MPH. It takes some work to get them replaced. Best left to someone who knows what they are doing, IMO. Once the bearings were out the mechanic showed me the "pitting" in the bearings. Mine only had the whine for about 3k miles, so yours are going to be a lot worse I would imagine.
