1998 F150 auto scanner it said it was the coil pack
check it with the auto scanner it said it was the coil pack
put a new coil pack,plugs, wires on it did not solf the problem.
the 98 ford f150 4.2 truck sounds like it's running on 4 spark plugs
hear it @ http://www.youtube.com/watch?v=PYlQZI4wx7g
thank for any help you can give me.
Can't really tell from the vid - lotts of shaking tho, make sure your wires are right . Theres been times in the past with older vehicals when I was sure they were in the right fireing order, still got them wrong somehow. Double check it..
You've got an ignition problem so go through the steps - Look up "misfire" in this forum for help.
Push your motor hard to wake your computer up , it will report new codes, if it's failing to do so since your latest work.
Take it out on the road and put the coals to her..
Good Luck
Good Luck
OBDII is a useful thing but it does'nt tell all!
you might have an injector problem as this reads the same way. You need a better scanner to shown if the injectors are opening and for how long.
The old method was to pull a plug lead till it made no difference and that was the problem cylinder.
