Would a bad valve cover gasket make engine run lean?
Guest
Posts: n/a
Originally Posted by 3304x4
run sluggish or lean? How bad are the seals leaking? I mean it's obviously enough to warrent changing them, but how bad is it? If your truck has plenty of oil their shouldn't be a problem with performance.
Guest
Posts: n/a
Bout a week ago did a system check and replaced oil and filter, tranny fluid filter gasket and pan, ext. housing gasket. I have K&N filter, plat 4 plugs, 9mm wires, and I replaced fuel filter a little over a month ago. I like to stay on top of things. Just noticed some leaks and wanted to service it. My truck just runs damn doggish and I wasn't sure if this may contribute to it or not.
