oil in the spark plugs
Old 02-10-2005, 01:54 PM
compton21's Avatar
i have a '98 f150 4.6l and while i was replace the spark plugs the #4 plug had oil dipping from it what could be the cause of this? the truck runs just fine. could use some help on this.
Old 02-10-2005, 02:38 PM
cliles55's Avatar
Was the oil on the external surface of the plug or was it dripping from the electrode? Perhaps you spilled excess oil recently while servicing and the oil streamed back while driving the truck?
Oil fouled? Or just wet? Have you been burning oil? Adding oil between changes? Smokes when running? Compression check with another cylinder?
Help us - help you!
Old 02-10-2005, 08:42 PM
compton21's Avatar
oil on the external surface of the plug and was it dripping from the electrode and it is not burning oil not adding oil
Old 02-10-2005, 11:22 PM
Bluegrass's Avatar
could be valve cover gasket failure.
Old 02-11-2005, 03:03 AM
Faster150's Avatar
could be that new spark plug lubrication system.
umm check ur intake manifold see if theres oil in the PCV. from blow by. or u could just have worn rings . or like the guy said probably just a head gasket leak
Old 02-12-2005, 08:55 AM
cliles55's Avatar
Have you found the source of the oil yet? Were you able to do the compression check of the cylinder(s)? Regardless, I hope you have solved your problem and that it was something easy and inexpensive.
Old 02-12-2005, 02:34 PM
rngr4x4's Avatar
I had the same problem when I changed my plugs. Hasn't caused any problems, just messy when you pull out the old one and insert the new one. Isn't on every plug either. I always thought it was probably the valve cover gasket. I had a Chevy Beretta with a V6 that was the same way. Who ever thought of the idea of putting those darn plugs down so deep anyways.
Quick Reply: oil in the spark plugs
