07 KR Whining Trans??
I have searched and come up with mixed reviews. My 07 5.4 KR 4X4 has 228xxx miles. The fluid does not smell or look burned. It is full to its mark and not low. 4X4 engages and works, hubs lock and unlock with no grinding
The Problem:
While driving I hear an increasingly louder whining noise, ( like what a bad power steering pump sounds like). Mostly from 40mph and up. It will go away when you let off the gas and back when on. It will not do it at idle revving the engine or turning the steering wheel, only while under load at speed. It shifts good, OD seems to work fine. I have no clue how the PO serviced the vehicle. I do know they towed with it as it has a popup ball hitch in the center of the bed for a gooseneck. No codes are present on my scanner. Any suggestions aside from take it to a trans shop? I have read some to say servos, as well as torque converter might be bad. Any help is greatly appreciated.
Thank you
The Problem:
Thank you
