Code 67 error code
Code 67 error code
Hello everyone. I have a 94 Lightning and I have a error code 67. The reason I noticed that the overdrive off light was on was because I put the truck in drive and it started in third and I had to shift it into second to get going. It seems I only have second and third. I replaced the neutral safety switch and it worked fine for about 30 minutes and then the overdrive light came back on. What could be the root problem other than the switch. Any help would be greatly appreciated.
