B&M Shifter question for e4od to C6 swap
A little bit confused as I search the internet for info because as usual there is a lot of conflicting info. I am in the process of swapping a 93 with e4od to a c6 trans from a different 93. I still need to hook up vacuum, figure out what to do with kick down cable but I don't believe the shifter linkage is the same length.
I figure I could solve this with a b&m shifter. I am seeing mixed reviews, do I need to buy a reverse valve body or do anything with the valve body to use use a floor shifter? If I can use the B&M to throw truck into drive revese park and neutral as it should that's all I need.
Thanks guys
Thanks guys
