'07 FX4 Xfercase & tranny mount
Hey All,
'07 FX4, 5.4 w/3:73s and ltd slip. The truck has 122k and is a daily driver w/zero off roading. I live in the rust belt but don't plow. I've been changing fluids every 50k w/synthetic and just switched to Amsoil for the diffs and xfercase. Having a local tranny shop drop the pan every 30k and using what ford calls for for fluid. That only changes about 5-6 qts though.
I'm feeling a vibration when I've got weight in the bed and taking a turn either direction (maybe 3-400 lbs and I'm starting from a stop, taking a turn). Nothing on the highway, just from a stop. I grabbed the drive shaft and it is rock solid at the diff but at the xfercase, the shaft and xfer case move up and down maybe 1/8-1/4". Has anyone heard of a mount wearing out?
Thanks GLC.
No, I did not.
I asked Amsoil if the had a friction modifier in the fluid and they said yes.
I just spoke to the machine shop who just replaced my u-joints and balanced the shaft and they said they would add the ford friction modifier.
Do you agree with their opinion?
I have only noticed this vibration about 3 weeks ago and my fluid was changed in the fall.
No, I did not.
