Synthetic Transmission Fluid
Old 04-29-2014, 08:19 PM
ahmad's Avatar
Hi All: I recently installed an 04 F150 4R70W transmission in my 97 F150.
I would like to know what you guys think about the use of a synthetic transmission fluid such as, Royal Purple MAX ATF. Thanks for your feed back.
Old 04-29-2014, 11:14 PM
mitymerc's Avatar
I used Amsoil full synthetic on a recent transmission rebuild for a supercharged Marauder. Great fluid, but its expensive. Amsoil claims to be Mercon V compatible on the label.
Unless you are towing a lot, drag race your truck or live where there are the extreme temperatures (hot or cold), I would think normal Mercon V should work perfectly fine.
Either way, I would install secondary transmission cooler and change the fluid on a regular basis.
http://www.amsoil.com/shop/by-produc...uid/automatic/
Old 04-30-2014, 10:50 AM
Roadie's Avatar
jbrew swears by the Amsoil trans fluid. By the way, what happened to jbrew? I haven't read any of his posts in a while.
Old 04-30-2014, 02:41 PM
beechkid's Avatar
I'm prone to Valvoline for the past 30+ years....and use their Maxi-life which is full syn, merc V compatible. never had a tranny failure either.
Old 05-01-2014, 12:21 PM
ahmad's Avatar
Thank you Guys: Yes I will be towing a car & trailer from time to time. I did remove the little transmission cooler and replaced it with a little larger one with a 10" fan. I also installed a Mag hytech DD deep dish pan. I have 4qt of the Royal Purple. If I buy the Amsoil would it be ok to mix the two? Thanks again.
Old 05-01-2014, 06:13 PM
glc is offline
No, I would not mix fluid. You need to do a complete exchange - 14 quarts or more.
Old 05-02-2014, 10:51 AM
mitymerc's Avatar
agreed. mixing fluid is not a good idea.
like I said above, Mercon V should work fine for what you want to do.
Quick Reply: Synthetic Transmission Fluid
