07 4x4 shifting issues
I have an 07 lariat 4x4 crew cab with the 5.4 flex. The issue that I am having is when I am driving in traffic, if I accelerate easy and the transmission downshifts, I get this slight rumble that almost feels like I just drove over a rumble strip. It only happens for a brief 1/2 second and then it will shift into the lower sear just fine. But it only happens when I accelerate easy. If I accelerate fast, it downshifts just fine. I don't have any other issues with shifting other than that. Does anyone have any suggestions please.
May not be the tranny - could be low-grade misfires:
https://www.f150online.com/forums/tr...le-strips.html
More ...
https://www.f150online.com/forums/tr...ghlight=rumble
https://www.f150online.com/forums/20...rumble+misfire
Good luck!
MGD
This sounds like the old torque converter mechanical lockup slipping. This was a common problem on the older 4r70W trannys. I had the problem with my 95 Mark VIII. A transmission fluid change fixed my problem. So, my recommendation is to change the trans fluid if it hasn't been changed recently and don't use any additives.
