Stick to Automatic switch???
on
Steering column from an auto including the shift lever and cables. Insert for PRND21 indicator that goes in the instrument cluster. PCM and harness for an auto. Stall converter and flex plate for engine. Drive shaft for auto and cab configuration. Clutch pedal bypass wire. I am not sure about the wires for the starting system but there may be some subtle changes. Is your truck a 4x4?
JMC
JMC
