2001 Clutch Noise
2001 Clutch Noise
replaced clutch,pressure plate, piolt bearing, and slave cyl. was leaking , then had knocking noise , allmost gone when clutch pedal is pushed in. thought maybe bad parts, replaced all parts including flywheel except piolt from diff.supplier, still there. what did i do wrong
2001 f 150 4.2 2 wheel drive reg cab
Rich
Rich
yes the knock does increase as you give it more gas even in nuetral and noise goes away if you push clutch in. the transmission is on straight and fly wheel is torqed at 60lb. yes new release bearing and slave cylinder both times the parts are correct and were matched up with original parts taken off.
on
When you press on the clutch pedal you remove the driving force to the transmission. If it knocks with the clutch pedal released then the noise is coming from the clutch pressure plate fingers hitting something or something in the transmission is knocking. The thrust bearing on the crank could be worn and is allowing the crank to walk under load. Check the fluid level in the tranny.
JMC
JMC
