Ditto. All other things being equal, you will lose less power through a manual than you will through an automatic. However, the actual amount will vary from transmission to transmission, as wella s with the individual operating conditions of that trans.
The same goes for the different drivetrain configurations. The 4wd system by itself is, for the most part, just dead-weight when in 2wd. When in 4wd, with the additional rotating mass, there will be some drag, but again, the actual amount will vary based on the gearing, lube, and temp of everything involved. There is no right answer.
10-30% through the drivetrain is a wide range, but there's really not much more accurate way to estimate it. You could always dyno the motor to get the power at the crank, then dyno the truck and measure the RWHP. Do a couple quick calculations, and you'll find that the drivetrain loss will generally be between 10 and 30%.
-Joe
'00 F-150, X-cab, 4x4, Lariat, 5.4L Off-road, Trailer Tow, Holandia Sunroof($1000)Mucho mods
98 Explorer bone-stock (Lemon Law Case in Progress)
Photo Gallery Here
I'm not smart, just a resourceful idiot with some spare time.
