Quote:
Originally Posted by varney
As I said earlier the slip yoke that goes into the back of the transmission has been replaced with a new yoke. I checked for play and the yoke has quite a bit of movement (seems more than I would expect for normal) inside the transmission extension housing. There is enough up and down movement to hear a bump when you shake the drive shaft. I looked at the old yoke that was replaced and it has several shiny spots which appear to be wear. Could this be caused by a bad bushing in the housing?
That's most likely your problem , you need that bubblegum grease on the spline - if that vibration hasn't already wore something out , it will soon..
How long has it been since you did the carrier bearings - I'm thinking rear end service (fluid) has been increased to every 15,000 - friction modifier breaks down pretty quick - I haven't used the ford factory modifier when changing mine because I've read that people have had continuing problems when doing so. last time I used Valvoline's additive and it still working well - I've heard Red-line is good as well.
Anyway, something to think about, it could be contributing to your problem.
I think if the bearing was bad it would leak. Then again it's possible that it may not. I'll see if I can locate the TSB's , I have them somewhere.
Here's a link to my f150 online gallery(lol) - Possible DRIVELINE VIBRATION causes -
http://www.f150online.com/galleries/...496&anum=10943
Found a few TSB's , they all said the same thing -
TSB -
Driveline - Clunking/Grunting Noise/Shudder
Article No.
04-1-6
01/26/04
^ NOISE - DRIVELINE CLUNKING/GRUNTING NOISE
OR SHUDDER SENSATION DURING LIGHT TO
MODERATE ACCELERATION AND/OR BRAKING
^ TRANSMISSION - DRIVELINE CLUNKING/GRUNTING
NOISE OR SHUDDER SENSATION DURING LIGHT TO
FORD:
1998-2004 F-150
ISSUE
Some 1998-2004 F-150 4X4 vehicles with a one piece drive shaft may exhibit a clunking or grunting noise and/or a shudder sensation from the driveline. The condition will typically occur during fight to moderate acceleration from a stop and/or braking. This may be caused by the slip yoke not sliding smoothly on the transfer case output shaft splines.
ACTION
To service, lubricate the slip yoke with Teflon Grease (D2AZ-19590-A). Refer to the following Service Procedure.
SERVICE PROCEDURE
1. Road test the vehicle to verify the condition.
2. Remove the driveshaft per Section 205-01 of the Workshop Manual.
NOTE INDEX (MARK) THE DRIVESHAFT YOKE TO AXLE FLANGE FOR REASSEMBLY.
3. Lubricate the slip yoke with 7-13 grams (0.25-0.46 oz.) of Teflon Grease (D2AZ-19590-A).
4. Re-index and reinstall the driveshaft per Workshop Manual.
5. Check the transfer case fluid level and add MERCON Automatic Transmission Fluid XT-2-QDX if necessary.
6. Road test to verify the condition is corrected.
Parts Block
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
040106A Lubricate The Slip Yoke 1.0 Hr.
With Teflon Grease
Vehicles With One-Piece
Driveshaft (Includes Time
To Remove And Install
Driveshaft)
DEALER CODING
CONDITION
BASIC PART NO. CODE
4602 42
Good Luck
