F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > Towing & Hauling
Thread Tools Display Modes
Old 07-30-2002, 04:27 PM
Vehicle: 1991 Ford F150
Unhappy I don't see mine in there
Raoul,
I don't see mine in there! 5.8L, Sup, Auto, 4X2
Old 07-30-2002, 05:43 PM
Goat Herder Extraordinaire
Vehicle: 1999 Ford F150
Sorry bout that, those are only 1999 numbers.
I see you have a 1991, give me a break, I was only in Kindergarten then.
Someone at this site: http://www.fordtrucks.com/ can give you the 1991 numbers, I'm sure.
Old 08-20-2002, 02:13 AM
Vehicle: 1989 Ford 150
Thanks for the info.
Over 8,000lbs with a f-150? Does this bother anybody else? Sure it can pull it, but....
Old 08-21-2002, 02:20 PM
Vehicle: 2005 FORD F150
Mine is able to pull 7200 but the bumper is only rated at 500/5000.
Old 08-21-2002, 02:39 PM
Right hmustang. All of the numbers listed above are for frame mounted hitches. I would hope that no one tries to hook up 4 tons to their bumper.
I think Ford also has a caveat, "when properly equipped", which implies the factory tow package and all options include therein.
Old 08-21-2002, 03:12 PM
Class VI reciever hitches are rated for 500/5000lbs. unless a wieght distribution hitch is used. None the less, anything over 7,000lbs is excesive for a f-150. The suspension wont handle it well, the brakes arent sufficient (trailer brakes are prone to fail or loose traction on slick surfaces because they "pull" on the load from the back), and the truck is not heavy enough to control the load. Unfortunately engineers and marketing consultants have teamed up to compete with a tow off war with other manufacturers. Basing pulling recomendations off the driveline is ignorant. Power and reliability is a consideration, but so is suspension, braking, and tires (yes the stock tires are underated to pull this type of load properly). In an ideal world this would probably suffice. Anybody that doesn't trailerl a load like this regularly lacks the experience to safely trailer such a heavy load, and anybody that has trailered a load like this on a regular base would recognize that they need a heavier duty truck . Drivers following too close, road conditions, climate, and human error make this world less than ideal. I am a mechanical engineering major, but I will not let some guy behind a desk tell me that I can pull more than my truck will control and stop under adverse circumstances based on gear ratios. I just have more respect for my safety and the safety of others.
Old 10-14-2002, 11:41 PM
Vehicle: 2001 Ford F150
Send a message via AIM to momule Send a message via Yahoo to momule
Spaceman.....I totally agree with what you said. Please tell us what kind of RV you tow behind your F150. And if it's safe I'd like to know how you have it set up.......hitch, shocks, swaybars etc...
Just wondering....
Old 10-15-2002, 03:02 AM
I dont tow an RV. I tow a 16' utility trailer about 3x a week with my f150 loaded usually between 2500-3500#. The most I've towed with my f150 is about 5500#. I have electric brakes and added leaf, heavy shocks, C rated truck tires (would go D if they were metric, but are hard to find in 31's). My father has a lawn and garden nursery, and I do all the contract installation. We have an old 1 ton that I tow anything heavy with, and its their for that purpose.
You'd be surprised how much difference the trailer makes as well. The trailer was a premium and has a 2-5/16" coupler. We specifically chose that because most 2" balls are only rated for 6000#. The axle placement and alignment, along with the weight distribution of our trailer makes it pull better than any other trailer I've pulled (probably about 10 or so others).
I would say most members on here have a safe setup and feel comfertable with it. My thought is that a trailer wieghing 8,000# will have more control over the truck than the driver will. I know I wouldn't be comfertable in front of that load in a 1/2 ton, reguardless of the trucks gear ratio.
Old 10-18-2002, 12:24 PM
Vehicle: 2000 Ford F150 7700
Send a message via Yahoo to jimmy-7700
Cool 5th wheeler towing
I have a 2000 F 150 7700 Ford with 373 gears K&N filter and Gibson Exh. It tows my Spinter trailer with double slideouts fine, sometimes as fast as 85 MPH, even 70 up hill, until I hit a good headwind, then it really slowsdown. The combination weighs about 12,800lbs. The tung weight is 800lbs. which is less then the three quarter ton carring capacity of my P/U.
Overall I'm very happy with combo. It's smooth and gives me great mileage year round.
Thanks for a great site to let other people share thier joy.
Jimmy_7700
Old 10-18-2002, 09:59 PM
Vehicle: 2003 FORD F250 SD 6L
Hi Jimmy Welcome!
Just curious...do you use a weight distributing hitch? If not, hows the steering at 85mpg?
Are you sure thats not 70mph downhill?
Anyhow...be safe and keep it on the road.
Good luck....OT
Old 10-19-2002, 12:44 PM
Hi old Timer,
Yes, I'm sure it was 70 up hill, because I pointed it out to my wife and was surprized myself, we were coming back from Utah this past summer in Wyoming and the hills are steep and when I saw the BIG one coming I mashed the gas to get up it. This was a trick or trade off I learned from driving semi. If you don't get into it out there, sometimes down to 25mph. and that really slow when you got to get home sometime the same week.
This is not to say the one I went so fast on the down, didn't get me over 50mph on the next big one. Those mountains are tuff on a 5.4. I have traveled with my heavy trailer on a lot of Mountains going south in winter and the ones in Wyoming on rte.80 take the cake.
The fifth wheel hitch is just forward of the rearend and puts some weight on the front end and it feels as sturdy on the road as it does when w/out a trailer, maybe better.
jimmy
Old 10-19-2002, 12:47 PM
I just want to add that a 7700,F150 has "D" raited tires and are a very sturdy tire. jimmy
Old 11-11-2002, 03:20 PM
Vehicle: 1997 Ford F150
Question Which rear axle?
How can I find out which rear axle I have?
Old 11-12-2002, 12:12 AM
Sure is hard for us folks to stay on topic isn't it? This started out to be good info from Raoul and then changed into a "Pick on the Screw Owners thread" (which Raoul joined in on.....shame on you !!) and then it got back on topic again. One of the reasons that Ford sells so many trucks is that they make so many different variations for so many different applications. One is no less a truck than the other.......although the testosterone level of the owner may suggest otherwise.
I'd have to say again that what Spaceman said is correct down to the commas and periods especially since he's on topic. F150 trucks, while they are rated to pull certain amounts are really NOT meant to be towers over around 6000 lbs no matter what you do to them and no matter what the owners manual says. Even the local RV dealer says that and he'd love to sell me a 26' RV.
I think that the really important thing that Spaceman says is that which relates to SAFELY pulling a trailer under whatever conditions you might encounter on the road......safe for both the driver of the tow vehicle and those on the road around him. Just because you can get it started and it doesn't blow out the tires or destroy the suspension doesn't mean that you can stop the thing in an emergency situation. Seems to me that for every wreck you see on the side of the road there's probably one dumbass and one victim.
Old 11-12-2002, 09:37 AM
Quote:
Originally posted by momule
...info from Raoul and then changed into a "Pick on the Screw Owners thread" (which Raoul joined in on.....shame on you !!) ...
LOL, that was four months ago but, I guess there's no statute of limitations on the messageboard. And I actually didn't join in, I started it. There is a forum here for every type truck except mine and the comment was my jealousy showing through. momule, you're older than me and I was raised to respect my elders so that's about as straight up an answer as I can give.
Steve should put the lock on them if he's going to sticky them.
He's been doing this long enough to know we can't police ourselves.
*Signature photo removed by admin*
*Tire and Wheel care is a good thing however, you were showing way too much buttcrack*
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
