Rear Shock replacement for towing
I am looking to replace the rear shocks on my 2011 F-150 Platinum. I tow a 8.5 X20 enclosed race trailer with it. Trailer is about 2900 lbs, car is 3000 lbs. Tools tires and stuff about another 500 lbs. All total just under 7000lbs. When the truck was new it towed perfectly level with my standard hitch set up. Now with 60K on it the front end is starting to lift. I am looking for suggestions on new shocks that work great for towing.
Bilstein HD's or a similar shock would be good for towing. But shocks aren't going to return you back to your level state.
Your springs are worn from the heavy loads so you'd either need to invest in something like an add a leaf to give your rear end extra lift so when loaded it's closer to level, air bags so you can raise the rear when loaded, or just new leafs.
I'd recommend the air bags if you spend a decent amount of time towing, they're a good investment.
on
Bilstein HD's or a similar shock would be good for towing. But shocks aren't going to return you back to your level state. Your springs are worn from the heavy loads so you'd either need to invest in something like an add a leaf to give your rear end extra lift so when loaded it's closer to level, air bags so you can raise the rear when loaded, or just new leafs. I'd recommend the air bags if you spend a decent amount of time towing, they're a good investment.
Although it wouldn't hurt to still replace the shocks with 60k on them, airbags would be the best bet to cure the sag. Add-a-leaf works too, but the change in ride height is pretty inconsistent with that. With the airbags you can adjust the level yourself. Firestone makes a good set. Ride Rite I believe?
