anything to lookout for when installing drop shackels?
i just bought 2" drop shackels from bell tech for my 1996 f150 regular cab short bed to level out the truck. does anyone have any comments about problems or suggestions to ease the install? anything at all is better than nothing. thanks.
Shacke install
I jacked my Supercrew up and put jack stands under the frame. Temporariloy jack under the pumpkin to ease tension in the springs and replace the shackles. I heard of one guy recommending Lithium grease to prevent future squeaking. I didnt use any and i have no noise. You may want to shim (2degrees) to eliminate any vibration around 55-60mph due to driveshaft angle.
Good luck,
C
Good luck,
C
