Anti sway bar
popeye65,
I have the same truck (mine is a flareside). I put the hellwig rear and front swaybar on. Remember, be sure to tell whomever you buy from if you have lowered it and how much. Lowered trucks need shorter bolts and sleeve/spacers.
The hellwig front and rear swaybars are the largest diameter and the cheapest. Hotchkis also makes the same diameter but are double the price. However, Hotchkis is considered the best because the front swaybar is hollow and reacts faster than a solid bar. There is also Belltech, and several others.
