How to replace front coil springs?
Old 06-14-2002, 02:03 PM
SGTBOB's Avatar
How do I replace my stock springs snd shocks with Belltech lowering springs and Nitro drop shocks? Any tips or tricks to make installation easier? Any info would be greatly appreciated.
Bob
Old 06-14-2002, 07:41 PM
01screw's Avatar
Not really any tricks to this one, you pretty much have to follow the instructions with the kit, altough I found that I could replace my springs without removing the brake caliper and tie-rod end as stated in my instructions. While supporting the lower arm with a floor jack I only unbolted the shock, then unhooked the upper ball joint and the stabilizer bar link, then lowered the arm for access to the spring. Make sure you undo the clips holding the brake line and the abs brake line before lowering the arm!!
Quick Reply: How to replace front coil springs?
