how do you ajust headlights
yeah the tool is the bomb. I got mine on ebay, it was like $13 but works great. Problem is that the bolt fo rheadlight adjustment is 4mm and you'll never find a 4mm wrench long enough to fit in there. The tool they make fo rit is specifically caleld a "ford headlight adjustment tool" and works great!
Under the hood, on the backside of the headlights you will see two small adjustment screws for each headlight, one to adjust up/down and the other for left/right movement. As mentioned by the others, you should have the adjustment tool and by screwing the adjustment screws in or out, the headlight will move accordingly.
