Air Bags... T or not?
I just purchased my Ride Rite kit. I am thinking about putting a T in the line to make them equal pressure and simplify airing up. I've read some posts that say this defeats the purpose of the bags though by allowing them to equalize when turning etc.
I'm now thinking of putting a valve on one side so that I can air up and then close the valve when towing to keep them isolated... any reason this won't work? The only downside I can think of is more connections to leak.
Maybe I'm ovethinking this hehe.
The problem with a "T" is that if you are ever trying to offset a weight difference (left to right), it's not going to work.
As far as side to side shift, I'm not sure how likely it is. The springs will still carry some weight, and the bags will keep the ride height higher. But I still don't like the idea a lot.
Here's another idea...
A lot of people route the air lines to the rear license plate. If you do that, you could make a fitting that screws in to each valve and ties them together. Basically build an external "T". You could air both up (or down) at the same time so they have the same pressure, and when you take the fittings off they hold their own air. Plus it means less fittings to leak on the truck.
