Sponsored by: CARiD
Harley Davidson AWD vs. F150 4wd
Old Oct 21, 2008 | 05:39 PM
BakerF150's Avatar
I currently have a 04 f150 on 36's and its 4wd with 2high, 4high, 4low. I am wanting to buy a harley f150 that says to be "AWD". My question is... Whats the difference? Would i be able to mud ride or lift up the harley the same as i did my truck? Do they make a a harley with 2high, 4high, 4low? Any info on this mess would be great.
Old Oct 21, 2008 | 10:50 PM
wandell's Avatar
The biggest difference is the AWD truck can use AWD on dry pavement. You will still be able to lift it like a standard 4x4.
Old Oct 21, 2008 | 11:08 PM
Jaho1979's Avatar
The AWD trucks do not have a low range or a true transfer case, only the AWD mode and 4h. This picture is from a Harley AWD truck...
So, you can lift them like any other F150, but if you use the 4Lo a lot (which I suspect you might with 36's), it may not be a good option.
Old Oct 21, 2008 | 11:24 PM
Paralyzer's Avatar
the AWD has a clutch pack in the transfer case to allow it to "slip" to prevent binding. it also gets a litlle less fuel economy and you lose the "fun factor" of a rear wheel drive vehicle...i personally wouldnt want one. My .02
Old Oct 22, 2008 | 11:13 AM
BakerF150's Avatar
what is the "fun factor" of 2wd? spinning the tires or donuts or what? i dont do any of that anyway. i really dont care for going in the mud either but just like it being big. 24's with 38's is probably not going in the mud. but im not trying to be smart just wondering what the 2wd offers for fun.
Old Oct 22, 2008 | 04:17 PM
BakerF150's Avatar
doesnt the 07 models have a button to push for 4x4 and what not instead of the turn ****?
Old Oct 23, 2008 | 07:43 PM
Jaho1979's Avatar
I am pretty sure all 04-08 F150's have the ****, regardless of model...at least I have not seen one otherwise.
Old Oct 23, 2008 | 07:47 PM
06yz250f's Avatar
my 07 has the ***. not a button.
Old Oct 24, 2008 | 08:32 PM
Eff One Fifty's Avatar
Hell yeah spinnin the tires! Dont be that old guy that says its stupid, everyone likes to have some fun with it sometimes. I can spin my 37's, and it looks bad ***.
Old Oct 24, 2008 | 08:36 PM
BakerF150's Avatar
im not a old guy... im 23 but have a procharged mustang gt for all that spinning tires stuff. im not talking down on spinning the tires just dont see much point in a truck doing it. I burn my mustang tires off all the time.
Old Oct 25, 2008 | 04:46 PM
the point in doing it in a lifted truck is that it just looks so much more bad *** spinning some 38's than some little bitch tires.
Old Oct 25, 2008 | 07:21 PM
BakerF150's Avatar
damn... hell yeah thats bad *** spinning some 38's. my 5.4 cant spin my 36's at all. what all you got done to the motor.
Old Oct 26, 2008 | 10:33 AM
Jaho1979's Avatar
No doubt the 4.88 gears help that out a little.
Old Oct 26, 2008 | 12:25 PM
BakerF150's Avatar
true true true.... My truck has 3:73 gears. so would switching to 4:88 gears, would that save gas? or is it just for better use having the big tires.
Old Oct 26, 2008 | 12:31 PM
Jaho1979's Avatar
Probably help a little on gas mileage around town since it would work less to get rolling, but on the highway, it depends, because with lower gears (higher number), the RPM's will be higher.
If I had oversized tires and a lift, I would definitely get lower gears though to improve performance and driveability.
