Bump steer kit?
Did the alignment shop use cams? If not your alignment isn't truly set, may be "in spec" at one end of the spectrum but not truly set-up properly. Have an FX2 I just took a 3/5 off and didn't have any bump steer issues.
It's got the camber kit and it is a spring drop. The bump steer is not too bad just want it to drive as good as possible. I'm gettin close after I raised the carrier bearing ( cut and weld ) ,realized that a rear sway bar can cause strange things to happen with the steering wheel and found out the hard way that 23" saleen wheel's have a dif. offset from front to rear. In the end it's gonna look sharp.
