Help Needed. (need part numbers for bilstien5100 front and rear)
Old 09-02-2011, 06:49 PM
STEVEO236's Avatar
Hi guys. The title says it all. I have found the 5100's online and im going to order them. But some of the sites im looking at have different manufacturers part numbers. I think im getting a decent price on them but not too sure? I found them for $147 online. If anyone knows of a better deal, Please speak up! lol! I could use the help! Might also do the ball joints while its tore apart. I probably wont be able to shake free long enough to do it on my own. so i will probably have my suspension guy do the work. What should the ball joints cost roughly?
Old 09-02-2011, 06:52 PM
MossyOak3006's Avatar
Don't know about the shocks, but lower ball joints cost about $25 each and upper ones cost probably just under $100 each. The upper ball joints are built into the upper control arms, so they cost more
Old 09-02-2011, 07:17 PM
STEVEO236's Avatar
Excelent! Thanks MossyOak, Ill probably just put some new one on there when they pull the shocks.
I do still need some part numbers on those 5100's if anyone knows them. I searched them on here too and found a couple different numbers for them.
I know they would be different for 2x4 vs 4x4... and i have a 4 wheel drive. But i cant seem to ge the numbers so i know which ones to order from.
I wonder if they changed the part numbers on the newer model shocks?? Just guessing tho??/
Old 09-02-2011, 07:36 PM
kingfish51's Avatar
Try here.
http://cart.bilsteinus.com/search/mm.../drivetype=4WD
The front are the ride height adjustable, the rear are listed as 5100.
Note, they have 2 part numbers each. Old and new.
Old 09-02-2011, 08:01 PM
STEVEO236's Avatar
Thanks Kingfish! Ill start comparing them now. I saw the old part numbers a coulpe times. I figured they might have changed them with the newer shocks.
Thanks for the help.
Old 09-07-2011, 12:54 PM
Ponyboy24's Avatar
Steveo236,
I'm looking for the same thing for my '05 FX4 and just posted a thread on them. I found all four at this Web site:
http://www.topguncustomz.com/Store/G...view=241174944
Hope this helps!
Quick Reply: Help Needed. (need part numbers for bilstien5100 front and rear)
