Keypad install
Old Aug 22, 2000 | 01:01 PM
FIRESVT's Avatar
Post Keypad install
I just finished the keypad install. This was an easy one hour job. What a nice addition. Thanks for all the info from this fantastic group. Now if I could just figure out how to eliminate the key completely. hmmm
FIRESVT Red 2000 "L"
Just starting
The learning curve has recently increased a degree or two. Best E/T 14.069 MPH 97.49
Old Aug 23, 2000 | 11:43 AM
FORDSALES's Avatar
I am jealous. I have had the key pad for more than a month but the handle has been on back of almost two months now. Don't know when it will arrive.
When it does and I start installing, any secrets that you discovered while you were putting it in?
jim@jimshaw.cc
Black 00, Swanson Chip (Superchip re-burn is on the way), 4.10's
super whites, Airaid w/10" Big Mouth filter, chrome wheels
AIM 2" drop shackles, Mobile1 w/FilterMag, clear corners
2000 E320, 1993 Cobra R, 1959 Corvette, 1949 Plymouth Coupe
Looking for a better paying job to support my L
Old Aug 23, 2000 | 11:56 AM
bobb's Avatar
Talking
Hi Jim,
The one thing that I had trouble with was how to route the cable in the door so that it would reach to the connector and not be anywhere near the window mechanism parts. I can't figure out how some of the others were able to do this so easily. I know the harness is supposed to be a few inches short but mine seemed to be about 5 inches too short even for the method suggested by ToyMan. I had to really rig the cable and remove the sheathing and cable tie it to the inner door. So, my cable goes from keypad around the window guide immediately in front of the keypad (so now the cable is effectively in front of the window towards the innner door opening)cable tied along the inside of the door skin, stretched to the connector. Bottom line, it's cool, looks good, and works great...
Silver 2000, Delivered, 2Mar00!
NLOC Member #344
[This message has been edited by bobb (edited 08-23-2000).]
Old Aug 23, 2000 | 02:33 PM
Hwy_2_L's Avatar
bobb - I thought the same thing about the wiring at first and almost went the route you did but figured out that you need to go on the outside of the window (between the glass and the outer door panel. You need to come off the back of the keypad and go up and across the top to the front of the door. With the glass up, you need to look up at the top of the door there is a track that has some holes drilled in it. That is where the pre-attached pins go. Once you get to the front of the door you can come back to the connector for the keypad.
Rick
Old Aug 23, 2000 | 11:45 PM
FIRESVT's Avatar
I thought at first the harness was too short until I remembered about the old posts telling us to look up at the top of the channel for the holes and lo and behold there they were. The only problem was getting that blasted back nut off and back on. Just take your time and use every swivel and extension in your tool box and all the neighbors and friends. Good luck
Just starting
Old Aug 24, 2000 | 12:09 AM
FORDSALES's Avatar
Thanks for the info.
Can't wait until mine gets here and at the same time a little worried about doing it and you have helped.
jim@jimshaw.cc
Old Jan 8, 2003 | 02:06 PM
jfinkbigdog's Avatar
Lightbulb HELP
I reviewed the article and really want to do it for my 2003 F150. I had the keypad on my previous Sport Trac and have already locked my keys in the new vehicle!
Anyway, I called one dealer locally in Dallas and he thought I was a nut....
Do you have any reference material about whether or not the wiring harness is indeed in the new 2003 F150 Supercrew trucks?
Old Jan 8, 2003 | 03:27 PM
RAN JR's Avatar
Re: HELP
Does your truck have keyless entry remotes, if so then it should have the wires in the door. You can also look up under the dash on the drivers side and look on the box mounted to see if it gives you a 5 digit number. The numbers will be big.
Old Jan 8, 2003 | 03:34 PM
Have Remotes and 5 Digit Code
I just verified the code is there and it's just like the Sport Trac I had with the keyless entry.
Why do the dealerships not have clue?
Where else can I go to get this done as I don't want to tear apart my brand new truck!
Old Jan 8, 2003 | 03:47 PM
E-LO's Avatar
I've been wanting to do this on my 99 but I've read that 99s don't come with the wiring. I guess I just need to take the door panel off and see if it's there.
Old Jan 9, 2003 | 12:06 AM
Fast Gator's Avatar
Don't waste your time taking the door apart, it's NOT there
Sorry, I took my 99 apart to see myself
Old Jan 9, 2003 | 03:04 AM
SpankDog's Avatar
Banned
Wow sounds like a cool mod, whats the total price for this?
Old Jan 9, 2003 | 03:28 AM
The Swede's Avatar
TRUCK OF THE YEAR - 2010
Is it on the 2000 ?
Old Jan 9, 2003 | 08:48 AM
E-LO's Avatar
Originally posted by The Swede
Is it on the 2000 ?
Did you see his sig?
Old Jan 9, 2003 | 09:09 AM
Silver_2000's Avatar
Is it on the 2000 ?
yes the wiring is on the 2000 - Check the How Tos on my site for info ..
Doug
