blower pulley
Old Dec 22, 1999 | 08:50 PM
n20boy's Avatar
Post blower pulley
Has anyone tried the downs blower pulley yet?
Old Dec 23, 1999 | 12:15 AM
JIGAWATT's Avatar
Question
I don't think they are ready to start sending them out yet? Im going to order one after the 1st of Jan. On a side note, I've talked to a guy in La. who is getting a smaller pulley for the supercharger.It sound's like its available from Sean Hyland Motorsport for about $120. I don't know anything about claimed boost numbers,or how much of a pain it is to put on?
JIGAWATT SVT#2698
Old Dec 23, 1999 | 12:22 AM
99SVT's Avatar
Yeah, SHM has a pulley out. Mine is on order and should be here in a couple of days. Will keep you posted on the installation/results.
Jerrod Gross
99.5 White Lightning
#1414, May 19,1999
Snuglid, sprayed on bed liner, 8.84sec/79.8mph (1/8th)(before mods.)
SHM mass air/conical filter & chip
Old Dec 23, 1999 | 10:33 AM
SCOTTODOG's Avatar
I called SHM and they said you have to remove the blower shaft to get the pulley off. Quit a bit of work for 2 psi. If you find a different way of removing the stock pulley let us know. Thanks Scott
Old Dec 26, 1999 | 01:05 PM
Yoda's Avatar
ok Aaron, where did you find it, I cant seem to find the blower pulley
Old Dec 26, 1999 | 01:27 PM
2000Silverbulletonorder's Avatar
It's too new to be listed:
http://www.autospecialties.com/new.htm#new
Old Dec 26, 1999 | 01:47 PM
Yoda's Avatar
oh, I went to the site trying to find it there.
Old Dec 27, 1999 | 12:55 AM
Aaron B's Avatar
ASP has a new pulley for our trucks. It is $109.95 and will give about 3 more lbs of boost. http://www.autospecialties.com/ (281)261-5811. They also make a pulley puller used by the Grand Prix people to remove the press fit pulleys from there eaton super chargers.
Old Dec 27, 1999 | 10:48 AM
Nathan's Avatar
lots of interest in these products I suspect. just wanted to bump this 2 the front
Old Dec 27, 1999 | 11:13 AM
MRBBQMAN's Avatar
heard it's pretty easy to break the snout with a puller on the lightning's eaton. don't know how you could apply for any drivetrain warranty once you used a puller on it. (it would be obvious, and the first thing you see, when you pop the hood ), on the other hand, a crank pully swap is a little more consealed
